I installed a BG consumer unit in August with RCBOs. A 6A RCBO failed in September - tripped and would not reset (outgoing circuit disconnected). A 32A ditto in December. Any known issues with BG compact RCBOs or is this just bad luck? Thanks Read more: https://www.diynot.com/diy/threads/faulty-bg-rcbos-anyone-else.516508/#ixzz5ctW7oKHC
I've had 3 or 4 problems with BG RCDs in the past, usually not tripping off at all or the touch voltage getting too high under test.
