Hello, My patio door lock has been faulty for years since i moved into the house. As you can see from the pictures there is a temporary fix, if i remove this i can not lock the door. I always keep the door locked because of this problem. Does anyone know how i can permanently fix this or do i have to buy a new lock? Any help is much appreciated, thank you.
The idea of pin you have covered up is to push in when door is shut so you can lift cam to enable lock to work
