Feature wall
Discussion in 'Tilers' Talk' started by mitan maisuria, Aug 13, 2019.
  1. mitan maisuria
    mitan maisuria New Member
    Hi all,
    I have built a feature wall/ chimney in my living room.
    The surfaces are mainly OSB (front) and general timber (sides). Please see the picture to understand better.
    Now, I was initially planning on using lightweight cladding to cover the chimney breast; hence didn't consider the materials I was using to build the wall to begin (OSB).
    In the last few days I have found some split face tiles which I really like the look of; but the question is; have I used appropriate materials to tile onto? chimney.jpg
  2. Hans_25
    Hans_25 Active Member
    Ideally I'd lay tiles on ply but given there should be no moisture isssues, OSB migt be alright. Seal it first though.
  3. teabreak
    teabreak Well-Known Member
    Getting one side of any wood based board wet will tend to cause it to bow. I made this mistake years ago when I boarded a fireplace with chipboard then wallpapered it with vinyl paper (one with lots of horses on bet you can't guess what my little girls were in to!) the fire place looked pregnant for about 6 months till it more or less dried out! At least seal the surface with something suitable for tiles (Not PVA) to stop the moisture penetrating and prevent the adhesive drying too fast, although the sealant on one side only might still cause slight bowing. I would avoid tiles and stick with the original idea of cladding. You could of course over board with thin tile backing board but that will bring it out a bit more.
  4. teabreak
    Nice neat job by the way!:)
  5. mitan maisuria
    Thanks for the response Hans, any tips as to which Sealant to use; or would they all be equal for what I am doing?
    Thanks for the friendly reply! I definitely don't want to end up with a 'pregnant looking ' wall LOL. The only downside I am finding with the cladding idea is the edging. I consider that I will be able to get natural edges using tiles as they tend to be staggered and I may be able to cut them similar to a normal brickwork corner edge; however as far as I can work out, external corner edging (for the cladding) only comes in very limited colours (mainly white and silver) and I am going for a brown slate look finish on the cladding, which I feel will stick out like a sore thumb
    Thank you so much!
  6. koolpc
    koolpc Well-Known Member
    How about papering it? The choice is endless.
  7. mitan maisuria
    Hi Koolpc, I'm after some kind of 3D effect on it as I really want it to stand out.
  8. koolpc
    Ok, i see.
  9. Hans_25
    Not sure really, either a sealant suitable prior to tiling (ask at tileshop) or may be SBR. My tiler used a blue coloured sealant but no idea what is was.
  10. sospan
    sospan Well-Known Member
    Hans_25 likes this.
