Feel very stupid, can't change this light bulb fitting
Discussion in 'Getting Started FAQ' started by mindy, May 6, 2018.
  1. mindy
    mindy New Member
    Hello,
    One room in my flat - the ensuite bathroom - has spot light fittings that don't screw out
    https://ibb.co/hyOWR7
    What do I do with that to change the bulb?
    All my other spotlights screw out as below:
    https://ibb.co/hHqT67
    Apologies for being so useless! :oops:
  2. DIY womble
    DIY womble Well-Known Member
    Can't enlarge picture assume it's got glass over the bulb, you will need to put a flat screwdriver preferably under both sides and prize it down from the ceiling it's spring loaded so go carefully
  3. KIAB
    KIAB Well-Known Member
    Might be a bit gummerd up, so reason why it ain't unscrewing.
    [​IMG]
