My neighbour & I had fence panels installed in concrete posts between our gardens about 9 years ago. I think they are overdue for respraying with preservative, but she has climbers entirely covering her side. If I have my side sprayed, will it do any good or will it be a waste of money?.
Hiya Dormouse Would have thought there was a greater need to spray her side. The climbers are probably keeping the panels wetter underneath. Best to do this in early spring, it'll give the plants a chance to recover. Remove the climbers carefully from 1 panel at a time. If you can pull the panel out it'll help prevent overspray onto the posts. Remember to paint on a calm day! Jockster
IMO spraying (with anything) isn't going to make a significant difference to the life of the fence. If you want your side done for cosmetic reasons - go ahead - but brush/roller (spraying in situ will make a mess).
Thanks jockster & GM. I'll try to get next door to lower her climbers but I'm afraid they have grown into the joins in the fencing. Maybe she'll cut them right down & allow them to regrow. Anyway I'll treat my side with a brush & hope for the best.
