Festool guide rail
Discussion in 'Carpenters' Talk' started by tore81, Dec 5, 2016.
  1. goldenboy
    goldenboy Super Member
    Couldnt be without my 2700mm rail.
  2. joinerjohn1
    joinerjohn1 Screwfix Select
    Great for trimming doors lengthways.
  3. Jitender
    Jitender Screwfix Select
    I went for the bag option, I purchased the nozzle piece separate as well. A bit expensive for this. But the bag does a good job. Fitting the adaptor piece is straightforward, (new saws apparently already have the nozzle so no modification necessary).
    I don't do woodwork as a professional job so getting an extractor at the moment isn't top of the lists.
    There would be times though when it's just easier if you only need to make a few cuts where the bag is going to be much easier than getting the extractor out and setting up etc. i.e need to trim the bottom of couple of doors etc.
