Filling a small chase
Discussion in 'Builders' Talk' started by Albion, Oct 8, 2018.
  1. Albion
    Albion New Member
    I'm a decorator and have agreed to fill a small chase for a customer in their new kitchen where they've had a socket put in (the chase is around 1.5 linear metres). I think it's an external wall, though am not sure as although it's a terraced row, the houses are staggered. I was thinking I would use a sand and cement render initially instead of bonding plaster (due to it being an external wall) and was wondering if I need to add a waterproofer/plastercizer? If so, can anyone recommend a small, inexpensive product I can use? Since it's such a small job, I don't want to have lots of big bags of plaster/render/additive left over. As a result, after rendering I was thinking of finishing it with Easi-fill, since you can buy it in small bags and I can always use it on another job. I was wondering what people's thoughts are about this - any advice much appreciated!
  2. Jord86
    Jord86 Well-Known Member
    SBR the chase then use ready mix bag of mortar to fill.
  3. Albion
    Albion New Member
    Thanks for the rely. So you don't think I need to add anything to the mortar? And would you recommend SBR over PVA because of it's waterproofing properties? The cables have been capped off with a plastic conduit - I'm presuming the mortar will stick to this ok?
  4. Richard_
    Richard_ Active Member
    Sorry for my ignorance, what is wrong with using plaster because it's an outside wall?
  5. Jord86
    The likes of bonding or browning plaster tends to attract damp into the wall, assuming it's a solid wall being a terraced house not a cavity wall construction.
    Though to be honest filling a small chase I'd probably use anything I had to hand if it was within suitability.
  6. Albion
    Albion New Member
    Thanks for the help. Sounds like I can use either mortar or bonding and that I don't really need to worry about it sticking to the capping.
