Finishing part-flowed Yorkshires
Discussion in 'Plumbers' Talk' started by Jimbo, Aug 1, 2020.
  1. Jimbo
    Jimbo Screwfix Select
    We've all been there - the most awkward joint ends up being part flowed. Of course ideally this should be disassembled and started again.
    When this has become apparent due to low-pressure air testing straight after the joint has been made, can the joint be reflowed?
    This seems to work OK as the solder appears nice and bright on the part not flowed. If the joint was dry, there would surely be too much surface tension for the solder to appear.
    But keen to hear thoughts and perhaps more importantly experience.
  2. ramseyman
    ramseyman Screwfix Select
    Wipe a bit more flux on and reheat, even though Yorkshire dab a bit of solder too as belt and braces
    Jimbo likes this.
  3. METRO MARK
    METRO MARK Active Member
    My wife has the same problem with part risen Yorkshires especially for Sunday Roast.
    Same thing all to do with the heat distribution.
    As above, on Solder ring fittings that fail
    clean off old flux residue with damp cloth
    slap some more flux on the joints
    heat joint moving the heat from centre of the end fed, towards the outer, coaxing the solder towards the slightly hotter part.
    Slip some more solder around the ring just to make sure.
    I brush the hot joint's with flux.....
    Then leave to cool on its own
    Then clean off with a damp cloth
    Jimbo likes this.
  4. Jimbo
    Thanks for the replies.
