Finishing/sealing kitchen
Chris4321
New Member
Hi,
Just finished fitting my kitchen and wondered what products you use to get a good final finish/am I right in my thinking.
Want to know which product and a recommended brand for each please!!
- Ash worktop to ash upstand seal (clear silicone? I have Dow Corning)
- Ash upstand to white painted wall seal (white caulk?)
- kitchen decor panels and plinths to engineered oak floor seal (clear silicone?)
- white mdf skirting to engineered oak flooring (clear silicone?)
- would you seal between wall decor end panels and wall? Walls aren’t amazing so there are some slight gaps. Is so with what? Clear silicone?
Thanks in advance!!!!
Hi,
- Ash worktop to ash upstand seal (clear silicone? I have Dow Corning).....clear will turn yellow in time and shows dirt....try and find a colour match silicone as best you can
- Ash upstand to white painted wall seal (white caulk?).......depends on the gap between wall and upstand......I personally don't put anything if the gaps aren't noticeable....but if they are then caulk is fine
- kitchen decor panels and plinths to engineered oak floor seal (clear silicone?)..........nothing at all. If your worried about damp then get yourself some clear plinth rubber strips
- white mdf skirting to engineered oak flooring (clear silicone?).......nothing needed
- would you seal between wall decor end panels and wall? Walls aren’t amazing so there are some slight gaps. Is so with what? Clear silicone?...........clear silicone won't hide a gap, possibly some white silicone or caulk
Back
Top
