Fireplace lintel
Discussion in 'Builders' Talk' started by Simon88, Sep 23, 2022.
  1. Simon88
    Simon88 New Member
    Any help here would be much appreciated..
    Currently opened up my fireplace and installed a new lintel:910mm opening with a 1200mm lintel inserted is this sufficient enough also found that I have another older lintel above it one more also in the bedroom fireplace just a diyer so any help would be great thanks Screenshot_20220923-013929.png
  2. Simon88
    Simon88 New Member
    Taken back to builders opening..is 110mm sufficient overhang enough on the lintel on each side?as is only 960mm opening to fireplace I have read that 100mm would be okay for that opening as it is under 1000mm wide hope someone can help before I finish up boxing it in thanks
  3. Jord86
    Jord86 Screwfix Select
    It’s more than fine.
    CGN likes this.
  4. Simon88
    Simon88 New Member
    Thanks for getting bk jord86
