First Time Plasterer Seeking Advice
Discussion in 'Other Trades Talk' started by AndyF55, Feb 26, 2014.
  1. Mr. Handyandy
    Mr. Handyandy Screwfix Select
    Sealant = sealant
    Bonding agent = for BONDING
    Bond-it = bonding agent(from thistle's site)
    PVA = Sealant and Bonding agent.
    I cannot say more.
    Mr. HandyAndy - Really
  2. BuilderMCR
    BuilderMCR Active Member
    I wouldn't bother saying more because your wrong...:D
  3. Mr. Handyandy
    Those above are facts!
  4. Please don't say any more...
    Sean_ork likes this.
  5. BuilderMCR
    So plaster has to be glued on is what your telling me...
  6. Sean_ork
    Sean_ork Screwfix Select
    is there a full moon tonight ?
    BuilderMCR likes this.
  7. BuilderMCR
    If I can't get hold of any pva then Andy I'll get a pritt stick. Thanks for the advice ;)
  8. Mr. Handyandy
    No, that's not what I'm telling you. Not always.
    In the case of non-porous surfaces, yes.
    That is what bond-it does.
    That is what PVA does.
    In the case of porous surfaces, no.
    Prevent suction.
    That's what PVA does.
  9. BuilderMCR
    And for the people who want a quick bodge job get blue tack. It'll stick the plaster to the wall
  10. BuilderMCR
    That's what I've been saying!! Suction control!..........
    It doesn't stick the plaster to the wall though. That's why you need some suction
  11. BuilderMCR
    If you have no suction you have to provide a mechanical key (blue grit etc. )
  12. Mr. Handyandy
    Don't take the p.
    Read the info on the websites. They say it. You seem to believe everything the manufacturer says, I'm just repeating it.
  13. BuilderMCR
    I don't believe everything the manufacturer says. If I did I'd be telling you not to use pva at all and use gyprime.
  14. Mr. Handyandy
    In the case of POROUS surfaces, yes.
    For NON-POROUS surfaces, you need ADHESION. There is no requirement for suction control here.
    That's why you PVA or Bond-it. For adhesion. There is no suction on non-porous surfaces.
  15. BuilderMCR
    And on porous surfaces it's the suction that creates the adhesion of plaster......
  16. Mr. Handyandy
    I'm glad you said that.
    So on non-porous surfaces, applied pva, what then creates the adhesion of plaster?
  17. BuilderMCR
    Put a piece of paper in a sieve
    The piece of paper is the new plaster
    The sieve is the old plaster
    Get a Hoover on the opposite side of the sieve
    You will see how suction works
    The piece of paper (new plaster) will be drawn towards the sieve (the old plaster) by the Hoover (the suction)
    This creating adhesion
  18. BuilderMCR
    Non-porous surfaces (no suction) which is when you have to create a key by using bond-it etc.
  19. BuilderMCR
    No try replacing the sieve with a bowl, this will be your non porous no suction background
    When you put the Hoover on the opposite side now your piece of paper (the new plaster) will not be drawn towards the Hoover because the no porous surface has killed the suction
    So this is when you use blue grit etc. to create an alternative key you wouldn't use pva on this type of background
  20. Mr. Handyandy
    Now line the sieve with pva and the bowl with pva.
    Then apply your paper(the new plaster). It sticks. Suction or no suction.
    It's called adhesion.
