First Time Plasterer Seeking Advice
Discussion in 'Other Trades Talk' started by AndyF55, Feb 26, 2014.
  1. BuilderMCR
    BuilderMCR Active Member
    Now we go back to the "don't use too much pva"
    You have a porous surface and you seal it so much it becomes non porous so you have no suction
  2. BuilderMCR
    But you don't use pva on walls with no suction! You use bond it etc.
    If you have no suction you plaster tears when your troweling up
  3. BuilderMCR
    The pva is to close up some of the holes in your sieve (seal them) so you don't have too much suction
  4. BuilderMCR
    If you keep this up Andy I'll have as many posts as you! ;)
  5. Phil the Paver
    Not to do with plaster, years ago I had to replace a terracotta tiled floor, we took the old tiles up, clean the existing concrete base ready for new tiles, the customer who was a scientist told us in no uncertain terms not to use PVA on the existing concrete and to only wet it using water and then bed the tiles, when we questioned this he explained that PVA was not a glue as such and would not aid the skicking down of the tiles, he said it would have the opposite effect and form a barrier between the concrete and the tile adhesive of which neither of them would stick to, were as water would evaporate slowly allowing the adhesive time to bond with the concrete. ???
  6. Mr. Handyandy
    Mr. Handyandy Screwfix Select
    No. Yes you do use pva on non-porous walls. It gives adhesion where there is no suction.
    Yes you use pva on porous walls. It prevents too much suction and aids adhesion.
    The grit in bond-it further aids adhesion.
    You know it makes sense.
    Mr. HandyAndy - Really
  7. BuilderMCR
    Exactly Phil, so by pvaing your sieve you are only sealing some of the holes, this allows some suction to adhere the plaster but not so much that there is no suction
  8. Mr. Handyandy
    Same goes for wall tiles.
  9. BuilderMCR
    No, pva is only for controlling suction.
    If you have no suction you have nothing to control
    If you have no suction you have no key
    So you use bond it to create a key which doesn't require suction
  10. BuilderMCR
    I feel like a fish in a bowl, I'm going round and round in circles.
    But you are understanding more the dizzier I get.
  11. Mr. Handyandy
    It's a glue. And pva is a glue!
  12. BuilderMCR
    Bond it is not a glue. The key comes from the aggregate.
  13. Mr. Handyandy
    Is bond-it a type of PVA with grit in it?
  14. BuilderMCR
    No!
  15. Mr. Handyandy
  16. BuilderMCR
    It isn't pva
  17. Mr. Handyandy
    Do you know what it is?
  18. BuilderMCR
    It's an aggregate based polymer 'primer'
  19. Phil the Paver
    I bet the OP wished he'd never asked. :p:p
  20. BuilderMCR
    I wish the op never asked lol
