I purchased and fitted a shower wall plate in our new bathroom. Water pipes connect behind. The front of the plate has two threads that take one-inch nuts, but I cannot find a bar shower that connects using a one-inch nut. Is there something I need to purchase to connect a bar shower to the wall plate, or so some bar showers come with one-inch connectors? Help greatly appreciated. C
Are you sure they're one inch nuts? They are more likely ¾”BSP at 150mm centres which virtually all bar showers will fit.
Thanks for your message, you are correct they are for a 3/4 bsp (I naively measured it wrong) - and the centres are 150. Thanks for your help! Much appreciated.
