Fitting a 'bum gun' bidet hose
Discussion in 'Plumbers' Talk' started by SeanyK, Sep 14, 2018.
  1. SeanyK
    SeanyK Member
    Hey folks, got myself one of these having used them on holiday, brilliant things they are...
    https://www.amazon.co.uk/gp/product/B074X1Y7FN/ref=oh_aui_detailpage_o03_s00?ie=UTF8&psc=1
    I wanted to mount it to the right hand side of the toilet, there is an MDF enclosure (see photos).
    In the pack, there is a 't-valve' which also has a turnable isolation, which, apparently, when not in use, you are supposed to have that turned off, so, you would need that somewhere easily accessible.
    My ideal install idea, would be to have the valve mounted on the side of the MDF enclosure next to the holder with the 'bum gun' in, however, as you can see in the photographs, the cistern fill point will not be close enough to do that, without me somehow moving it closer to the mdf part.
    I was just wondering the best way of doing this, would it be feasible to use a different 'tee' piece off the cistern to the one supplied, and have that run to a hose outside of the mdf enclosure? If so, any recommendations on parts from Screwfix?
    [​IMG]
    [​IMG]
    PS> Ignore the 'blue' cable from the flusher, I never fitted this toilet originally :D
  2. kiaora
    kiaora Well-Known Member
    Hi
    If you have mains water supply, it’s against the water regs io install it.
    There is a high risk of contamination to the water supply
    Regards
    Peter
    Heat likes this.
  3. SeanyK
    SeanyK Member
    Really? They are all over the place for sale, would the backflow protection not solve that issue??
  4. RolandK
    RolandK Active Member
    Am I missing something? Don't these connect to the outlet of a mixer like a shower hose?
  5. DIYDave.
    DIYDave. Well-Known Member
    Never seen one myself but looks like no fixings on actual valve itself to
    mount onto cistern housing
    So you need rigid copper pipe to enter and exit valve I guess to hold it in place
    Needs to be neat as connections are gonna be outside of cistern housing, along with valve
    Pretty much anything in plumbing can be connected either with copper, placky or flexi pipe and compatable connections
    Just needs a little planning as it’s all gonna be on show
    But once it’s all working, wow, what a great feeling. You can’t beat a nice shiny ring :)
  6. RolandK
    I don't see that they can connect direct to the mains. Cold water at mains pressure would cerainly wake you up in the morning! I'm going to stick my toilet brush with a squirt of Cif bathoom cleaner.
  7. kiaora
    A hose union or other tap to which a spray or jet may be attached at the outlet, and which may be located adjacent to ordinary WCs or squatting toilets, is a fluid category 5 risk, in that the tap outlet could be contaminated directly with urine or other matter and, if a hose is provided, the spray or jet could be deposited in the WC. Taps for this purpose must not be supplied with water from a supply pipe, but can be supplied from an independent distributing pipe providing that the highest part of the zone of the backflow risk is not less than 300mm below any cistern serving the tap (see Diagram R15.12.2)
    Category 5 , to be tank fed.
  8. just pumps
    just pumps Active Member
    Thought it was a separate tank. (?)
  9. dobbie
    dobbie Well-Known Member
    I would be repairing the dodgy connection to the cistern and redoing it.There is too much strain being put on the ball valve tail, pushing it upwards with pipe and connectors being too long.
  10. SeanyK
    SeanyK Member
    I can repair that connection when I do this job so do both at the same time which will be good :) I have copper pipe already, so could just get some brass olives and the nuts to fasten.
    Just trying to see how I can get it all connected properly and correctly... Almost like I need a 3 way check valve!
  11. Isitreally
    Isitreally Well-Known Member
  12. The Teach
    The Teach Well-Known Member
  13. HarDeBloodyHarHar
    HarDeBloodyHarHar Active Member
    No advice from chippie on the 'bumgun' then?
    retiredsparks likes this.
  14. sospan
    sospan Well-Known Member
    Surprised the thread has lasted this long :rolleyes:
  15. SeanyK
    SeanyK Member
    Just a question, I have abandoned the idea of the hose one, however, does this also need the same regulations as a category 5 fluid risk?
    https://www.amazon.co.uk/YEGU-Attac...204011&sr=8-2-spons&keywords=bidet+seat&psc=1
    This is one that goes under the seat, not having a hose attachment or anything like that, so would this simply be a case of plug into the water fill of the cistern, tee off it and off you go ?
    (they look a bit ugly to be fair but if it gets the job done...)
  16. just pumps
    Saw one these a couple of weeks ago, it was tee'd of the supply to the cistern as you say. I'll take a guess and say it's ok.
  17. Magicspark
    Magicspark Active Member
    Looks unhygienic.
  18. The Teach
    SeanyK,that supply's a warm wash experience.Seen in advertising for other similar units that it is piles better or better for your piles,cant remember.
    Still needs to be fitted by a registered plumber but its your call :p
  19. SeanyK
    SeanyK Member
  20. just pumps
    Why the registered plumber Teach?
