Fitting a deeper window
Discussion in 'Builders' Talk' started by Geo Cee, Oct 31, 2020.
  1. Geo Cee
    Geo Cee New Member
    Any idea of the rough cost for replacing a bedroom window with a deeper window. The width will remain the same so assuming the lintel that is there will be sufficient. The window is just very shallow. Looking for labour cost only as the window will be supplied. Thanks.
  2. ginger tuffs
    ginger tuffs Screwfix Select
    you would be better to get a window installer in to supply and fit post a picture of what you require
  3. Geo Cee
    Geo Cee New Member
    thanks. It’s actually a house we were considering buying, the the window is really shallow. So can’t post a pic. But was just trying to see if we are talking hundreds or thousands to do something like this.
  4. Frutbunn
    Frutbunn Active Member
    Factor in building reg fees as well, it can't be self certified under the FENSA scheme
    Geo Cee likes this.
  5. stevie22
    stevie22 Screwfix Select
    It's a couple of days work tops for a jobbing builder. Most folks wouldn't bother with regs for this, and yes lintel will be fine.
  6. Frutbunn
    Until they come to sell and they come to B Control wanting a Regularisation Cert ASAP.
