Fitting an induction hob into a "marble" worktop
Discussion in 'Kitchen Fitters' Talk' started by Kevinfleet, Aug 12, 2018 at 11:12 AM.
  1. Kevinfleet
    Kevinfleet New Member
    My daughter wants to replace a gas hob with an induction one. The new new hob is about 2mm wider than the existing hole. What's the best / easiest way to make the hole bigger - I'm concerned we might damage the worktop; it's about 10 years old and is the composite type with shiny metal flecks in the surface. I'm thinking maybe using a grindstone attachment on a drill??
  2. DaveF
    DaveF Member
    A small (4"~4.5") grinder with a 120grit diamond wheel on it. Place some masking tape on the stone to define where you need to sand to - so 2mm from the current edge, and sand to the edge of the masking tape. Just make sure the direction of the blade is always downwards when you touch it against the marble. It is helpful if the grinder is variable speed.
  3. kitfit1
    kitfit1 Well-Known Member
    For 2 mm a grinder with a diamond wheel is perfect.
