Hi, I've bought these for my cabinets https://www.screwfix.com/p/sylvania...Vxp3tCh1QUQ5vEAYYASABEgLQnPD_BwE&gclsrc=aw.ds I'll be honest i've only browsed at the install kit, but I'm a bit reluctant to screw them in. Is it advisable to screw them in to the bottom of the cabs OR use double sided tape? My main reason for not screwing in is whether i need to change them in future.
Just use the brkts supplied & ensure screws are suitable. Screw holes would not be a problem should you replace fittings at a later date as they are on the underside of cabinet and not readily visible.
