Fitting light to artex ceiling
Discussion in 'Getting Started FAQ' started by Graham Oliver, Aug 11, 2019.
  1. Graham Oliver
    Graham Oliver Member
    Hi everyone (again),
    I need to fit two new light fittings to an artex ceiling (confirmed asbestos) and really don't want to drill.
    Is there any other viable alternative? Strong adhesive pads, for example?
    Thank you in advance!
  2. gas monkey
    gas monkey Well-Known Member
    self tappers no drilling
    putty over hole to be hand drill no fibres spray paint as removed seal
    fix all is a good one will need support until it goes off
  3. PawelM
    PawelM New Member
    Might work for you:
  4. gas monkey
    am an expert been doing it for years get a ticket every 5 yrs
    you should never drill with a power tool
    shaving foam can blow off
    putty is the approved method drill by hand
    or pay someone to do that cos thats what they will do
  5. Graham Oliver
    Thank you. Would normal sealent do the same job or is putty better?
  6. gas monkey
    its a thoght but when trained it was putty but can see nothing wrong with that as it want blow off so he who dares
    Graham Oliver likes this.
  7. Wayners
    Wayners Well-Known Member
    Just put a screw through. No need to drill its plasterboard. Why do people think they're need to drill? I put 1000s of screws through plasterboard and never drill first. A bit of bluetac and put screw through if you are parinoid. Leave the bluetac stuck there
  8. teabreak
    teabreak Well-Known Member
    Or a blob of silicone/mastic and go through that I guess will work too.
    Graham Oliver and Wayners like this.
  9. Wayners
    Yeah.. Brilliant
  10. Graham Oliver
    Thanks everyone
