Fitting mortice lock
Discussion in 'Carpenters' Talk' started by Jay459, Nov 11, 2020.
  1. Jay459
    Jay459 Member
    Is it possible to get a mortice lock with euro lock on internal firedoors.
    Need to add a lock to kitchen door and must be keyed on both sides with escutcheons.
    Just wondering if euro locks are possible on internal doors
  2. Jay459
    Jay459 Member
  3. I-Man
    I-Man Active Member
    you want a euro lock handle, plus whichever length euro cylinder is suitable for your door + handle thickness
  4. Jay459
    Jay459 Member
    So you have to change handle?
    Maybe ill just go for basic mortice lock then as thought you could do it with lock and escutcheon
  5. I-Man
    I-Man Active Member
    you've picked in your link a euro mortice that has the latch also - of you don't want to change the door handle, then you want a euro profile deadlock without the latch. Then you can get separate escutcheon.
    eg https://www.screwfix.com/p/smith-lo...profile-deadlock-64mm-case-44mm-backset/3965p
  6. Jay459
    Jay459 Member
  7. I-Man
    I-Man Active Member
  8. Magjul
    Magjul Member
    Is this fire door on an escape route?? If so , MUST NOT be locked.........
  9. ginger tuffs
    ginger tuffs Active Member
    if you do fit a lock it as to be a firerated lock
  10. Jay459
    Jay459 Member
    Its just a lock for my kitchen door which has outdoor access from either side. Just need a lock to keep my infant son from accessing kitchen, euro lock seems best as i dont think he will pull key out as easily.
    I ordered the lock without the latch btw.
    Door is 44mm, escutcheon is 6mm on each side, so thats 56mm and ive ordered a 60mm euro lock.
    Does this sound ok?
  11. Jay459
    Jay459 Member
    Are you sure about this? My joiner is calling to do this next week and he said your best of fitting one thats combined. He sees no reason why you would be changing door handle if you did
  12. I-Man
    I-Man Active Member
    So does your existing door handle allow enough space below it for a seperate escutcheon to fit into the mortice lock? It's unlikely, hence you either get a mortice lock with the latch, and get a handle which accommodates the lock.... Or you have a seperate latch and mortice lock, in which case the lock can placed anywhere that space allows
