Fitting multiflex hose problem
Discussion in 'Plumbers' Talk' started by Dastardley, Jun 14, 2018.
  1. Dastardley
    Dastardley New Member
    I'm replacing my monobloc taps in the kitchen. I have the old taps off and am now putting the new one on. I have the tap secured to the sink. I have both flexihose in at the tap end and one connected up to pipe at the other end with no problem.....but the other flexi hose is a right bugger.....for the life of me I can't do it up without water leaking out the top of the flexihose connector and running down the pipe....Can anyone tell me what I can be doing wrong? What would cause this? Any help much appreciated.
  2. Vin
    Vin Member
    The only thing I can think of without seeing it is a missing O ring where the flexis screw into the tap
  3. Dam0n
    Dam0n Active Member
    take a quick picture so we can see what fitting is on it. cheers
  4. Dr Bodgit
    Dr Bodgit Well-Known Member
    As above, missing o-ring or not done up sufficiently is all I can think of too. Its leaking at the top of the flexihose where it screws into the tap base?
  5. Dastardley
    Here are some images.
  6. Dastardley
    No leaking from other end...top the flexihose connector where it goes on to pipe fitting.
  7. Heat
    Heat Well-Known Member
    You are connecting that wrong!
    The washer on the flexi hose is flat and MUST be connected to a flat faced fitting!
    You can use 1/2” x 15mm male fittings ( straight or elbow )
    Or you can buy from Screwfix fittings for the purpose.
    That elbow you have is tapered inside and has a sharp edge for a pipe and olive to go into. The rubber washer will get cut and risky to join like that.
    If you had spare 15 mm rad valve tails, they would also do to take you onto a flat face
  8. Dastardley
    Thanks mate....these are the fittings that my kitchen fitters used five year ago....i just changed the tap...like for like. I'm 100% amatuer.....just thought all i had to do was replace like for like...Thanks for letting me know. Might just have to call a plumber to do the rest.
  9. DIYDave.
    DIYDave. Well-Known Member
    Uv got this far, just another push and you’ve done it (pat on the back time) :)
    As heat says, not a good connection between washer and tapered edge, with possible damage to washer
    There’s millions of flexis connected direct to isolation valves as an example, these also have a tapered edge
    Probably most of them don’t leak, but the odd few will
    Take a look at ‘tap tail adaptors’, 2 in a pack, 15 and 22mm available
    Compression on one end which tightens onto 15mm copper pipe, then a nice flat face to seal against washer as you screw on flexi
    If washer is damaged on flexi, you can prise off and replace
    You can do this :)
    Heat likes this.
  10. StoneMan
    StoneMan New Member
    I am with DIYDave on this one. If you bite the bullet, have another go with a different connector I am sure you can do it. It's not too difficult. Good luck
  11. StoneMan
    StoneMan New Member
    If you unscrewed the brass elbow with a spanner, ( the nut and olive can stay on the pipe) and replaced it with this one. https://www.screwfix.com/p/p802-08-male-elbow-15-x/44344 It has a flat face on the fitting so would almost certainly work well with the existing flexi tail pipe you have fitted. Simple straight swap, in my eyes at least :)
    Heat likes this.
  12. Heat
    Just replace that compression elbow with a 15mm x 1/2" elbow and you have that one ready for to connect flexi tap hose straight onto it.
  13. Heat
    I wasn't copying you StoneMan, we just were thinking alike and posted same time. :)
    Just one thing I would add, - that Screwfix male elbow looks like it will swap over and connect to original nut and olive.
    But just be aware some rubbish brass fittings are about now that don't have the same depth, so original olive would be too far onto the pipe.
    retiredsparks likes this.
