Have just had all new rads installed. Great job, except the plumber has positioned the pipes of 1 rad a bit too low. There isn’t enough room for the floor tiles and skirting I’m going to fit. Is it a simple/normal job to fit skirting, by cutting 4 small sections around rad clips, or would you call back the plumber to try to rectify it?
For ease, time, good relations with the plumber and any other reason, in this instance grit your teeth whilst cursing, and notch the skirting to suit.
