Hi all, Our chrome towel radiator has a crack in the pipe leading to the valve connection. I worry it does pass under the connection nut which may make it harder to fix. It does leak, so definitely not just cosmetic. Radiator is currently drained. How best to fix it and what to watch out for? Thanks in advance for all ideas.
Is the pipe copper,or plastic ? Can you show us pics ? If the pipe comes straight up thru the floor ,it may have some free play to raise it up ,cutting off the damaged part. Or is the crack above the valve ??
