I am going to have a screed floor. I am burying some JG pipe in conduit in the screed. How do I fix the conduit to the floor insulation before the screed goes down?... The staples used in underfloor heating only fit pipes without the conduit... so what would you use when the pipe is in conduit?.. thanks to any responders!
Thanks Peter, I have 2 different conduits one for 15mm pipe and one for the 22mm pipe. The 15mm conduit has an outside diameter of 24mm and the 22mm conduit has an outside diameter of 30mm I just thought they might sell clips / staples specific to the conduit, but that doesn't appear to be the case. I will go down to a store and find a solution!
Whilst the insulation was being laid used long cable ties through the insulation leaving them in a loop,then run conduit through the loops and gently tighten the cable tie,never failed
