Fixing freestanding cabinets
Discussion in 'Kitchen Fitters' Talk' started by Steve Spiteri, Jun 15, 2018.
  1. Steve Spiteri
    Steve Spiteri New Member
    Hello All
    I will shortly be fitting my kitchen cabinets, my first attempt at doing so. We will be having a u shaped kitchen, two sides fixed to a wall, the other exposed at the rear.
    I take it the best way to secure the exposed side is to drill through the legs into the floor, or is there some other preferred method, maybe timber batons (themselves fixed to the floor) running on the inside of the legs, to stop any lateral movement of the cabinets.
    Any advice appreciated.
    Steve
  2. kitfit1
    kitfit1 Well-Known Member
    As long as all the other cabs are fixed to the walls and each other, the worktops bolted together and screwed to the cabs. There is no need to do anything with the "floating" side, it won't move at all.
  3. Steve Spiteri
    Cheers kitfit, that saves me a job
  4. goldenboy
    goldenboy Well-Known Member
    If it feels a bit "wobbly" on the peninsular bit after the tops are on, squirt a little expanding foam around the feet. Stops the legs winding down or wiggling about.
  5. joinerjohn1
    joinerjohn1 Screwfix Select
    What are you putting across the back of the exposed units?
  6. Steve Spiteri
    Hi, our plan is to put some batons on the back then board and tile it.
