Ok, so i'm starting the staircase job... Can anybody with any previous experience tell me whats the best way to attach the hand rail to the newel post without any nails showing...? I've come up with a couple of solutions, but i'd love to know what the correct way of doing this is... Many thanks
tell us what u think first if it is no gooi will tell u the best way. you have to try first or ther is no point
handrails sorry mate was only jokeing. the easy way is to drill two 13mm holes both sides of top of rail 1/4 of the way pilot the holes after sink to screws and plug it. sorry mate dont forto glue it first. 2nd way is called a hanger bolt and the last way is a mortise method. no wrong or write way you do which you think easy good luck
i normaly mortice and tennon with offset dowels you can ether make a feature off the dowels or cut them flat big all
Cheers for the advice. Sorted it now. I used holes with countersunk screws as mentioned above. Solid as a rock, and i didn't use any nails.... Thanks for the help
syholl well done mate. stairs look hard but the moor you do the easyer it gets,any problems with your mates job , this is the site
