Fixing huge gaps in a shed
Discussion in 'Carpenters' Talk' started by Paul-TheNovice, May 12, 2018.
  1. Paul-TheNovice
    Paul-TheNovice New Member
    Hello,
    So last weekend in the sunshine i finally cleared out the shed or playhouse as my wife calls it. We had not used it since we moved it and it looks like its sat idle for a few years.
    I wanted to ask what are the best ways to waterproof/fix the holes. The panels are solid but just with huge gaps (as can be seen in the pictures) and also there are plenty of other parts between the roof/walls with holes. I guess i can do that with waterproof bathroom filler but the large panels?
    Thank you!
  2. mr moose
    mr moose Active Member
    Fix plywood on the inside and then clear silicon or a matching acrilic sealant in the gaps on the outside.
  3. Wayners
    Wayners Active Member
    Get thin ply and cut or get it cut as that what I would do sourced from local hardware store You can treat it with clear primer preserver if you want and stick on. Tack wood quadrant around edge to help hold in place if required. Cheap enough
  4. WillyEckerslike
    If you use any silicone product you wont get a stain or treatment to adhere/absorb properly in future.
  5. Wayners
    6mm ply. 12mm screws and grind off any that make it through. Scrap quadrant idea thinking about it.
  6. Josh.91
    Josh.91 New Member
    Foam. Everytime.
  7. Wayners
    Sunlight will turn it to dust
    Astramax likes this.
  8. masterdiy
    masterdiy Active Member
    Re-clad the outside. Feather edge board, same stuff they use for fencing.
