Fixing Ledger Board to Brickwork
Discussion in 'Landscaping and Outdoors' started by mogsta22, Jul 8, 2013.
  1. mogsta22
    mogsta22 New Member
    Can someone advise on the best type of bolt from the screwfix catalogue to fix a 6x2 ledger to a brick wall. I am building a deck and getting totally confused as this is all new to me. I know I need a minimum 10mm gap between the ledger and the brick and am planning on using washers for this unless someone presents a better solution of course.
    Any help is much appreciated.
  2. chippie244
    chippie244 Super Member
  3. mogsta22
    mogsta22 New Member
    Many thanks Chippie they sure look like they will do the job right.
  4. Mr. Handyandy
    Mr. Handyandy Screwfix Select
    Don't forget top and bottom fixing, not just middle.
    Mr. HandyAndy - Really
