Fixing natural stone copings to brickwork - not using mortar?
Discussion in 'Getting Started FAQ' started by Tiger69, May 15, 2019.
  1. Tiger69
    Tiger69 New Member
    Hi, I have a low height single skin brickwork wall with some natural stone copings on it. The wall is basically at single step height between my patio and my lawn. The stone copings have been previously fixed and re-fixed using sand and cement mortar MULTIPLE times over the last few years, but, as I mentioned, because the wall is at step height, these copings have been loosened as people have actually stepped on them. I am thinking of fully cleaning the underside of the copings and the top of the brickwork and then using something like Everbuild's Pinkgrip adhesive instead of mortar. Will this do the trick?
    Thanks.
  2. dobbie
    dobbie Well-Known Member
    You could use an epoxy resin,something like Akemi,if you use that the bricks/copings will break before the joint.
  3. robertpstubbs
    robertpstubbs Active Member
    You can get clipover copings (List No 450 etc) for single brick walls. There are other interlocking types for thicker walls. But just using resin should be enough.
