Fixing sizes descriptions
Discussion in 'Builders' Talk' started by Paddington, Apr 29, 2009.
  1. Paddington
    Paddington New Member
    Hi
    Can anyone explain to an amateur what the following means please:
    Studs M8 x 110mm Drill Size 10 Max Fixture 75 Pack of 5
    What are M sizes? Is is the diameter in mm of the stud?
    What is Max Fixture 75?
    Last question - I hope to fix a 1m post to my house wall so my gate closes against it. The wall is blockwork and I've been told to use resin to fix studs. Would 3 be OK and how deep does the stud need to be buried in the wall ?
    Thanks very much.
  2. mr sillys
    mr sillys New Member
    the first stud is always the deepest
    m
    cheers
  3. chippie244
    chippie244 Super Member
    M8 means the dia is 8mm
    Drill size 10 = use 10mm drill
    Max fixture 75 = maximum thickness of fixture 75mm
    I'd use all 5 and get them as deep in the wall as you can.
  4. Paddington
    Thank you very much chippie. Your help is much appreciated.
