Fixing to dot&dab walls
Discussion in 'Builders' Talk' started by mrppp, Jan 18, 2019.
  1. mrppp
    mrppp Member
    If fixing to a dot & dab wall, am i just best using longer screws, then push rawl plug into blocks/bricks on other side?
  2. goldenboy
    goldenboy Well-Known Member
    Depends what you are fixing to be honest.
    Always a bit hit and miss on D+D.
    Depends on depth of void. Depends on whether you need to fix where there is a dob.
    Generally if its a void and its a lightweight fix, then a spit spiral fixing will do.
    If you hit a dob and its lightweight fix then a 6mm hole and a brown plug and say a 60mm screw will do.
    If its a heavyweight fix then say a 100mm screw into bricks/blocks will be required.
  3. mrppp
    mrppp Member
    Well to hang a TV ( 26") and large mirror (heavey) and curtain poles. No guarantee a dot will end up where needed. ( hate dot and blinking dab). So am i best with 8mm rawl and 100mm screws?
  4. Jord86
    Jord86 Well-Known Member
    100mm screws, brown plugs, if you really really are struggling for a fix cut out a square of plasterboard neatly, PU glue and screw a square of ply or 4x1 in the hole, refit the plasterboard then screw into that.
  5. DIYDave.
    DIYDave. Well-Known Member
  6. mrppp
    mrppp Member
  7. Dryline does not have the steel cylinder core that helps to transfer the weight to the masonry wall. Corefix seems better because of that. I plan to use them to mount 30kg radiators to the walls.
  8. mrppp
    mrppp Member
    If I use 100mm screws, can you get rawl plugs that length? Thinking of these
  9. DIYDave.
    You haven’t got 100mm of screw going into plug though have you ;)
    Take off the following;
    Thickness of item being fixed
    Approx 3mm plaster skim
    12.5mm plaster board
    D&D gap - could be anything really, 25-50mm
    Approx 50mm (ish) going into wall and plug :)
    Drill correct size hole depth and size through PB into wall
    Push plug into PB, couple turns of the screw by hand then push plug through PB ans into hole in wall
    Light tap with hammer to drive plug into wall using screw
    Remove screw and fit item
  10. mrppp
    mrppp Member
    But ideally i need the plug flush with plasterboard rather than fully pushing in to wall.
  11. mrppp
    mrppp Member
    I will just try with normal 8mm plugs, 100mm screws, if no good get some of the Corefix .
  12. DIYDave.
    Why ?
    Plastic plug filling gap between wall and PB doesn’t offer you anything
    That’s what steel sleeve on Corefix offers, yes your paying for this but what price in piece of mind
    If you overtighten screw into plug and you have a void behind PB, you run risk of PB deflecting and either PB and/or plaster cracking
    Again Corefix stops this chance
    Anyway, just an option :)
    WillyEckerslike likes this.
  13. goldenboy
    100mm screws with brown plugs will be fine.
    Angle the drill downhill slightly to create a hook effect.
  14. Jord86
    You can't have everything, no point having the plug flush with the plasterboard if it's just a void behind. Push a second plug in deeper if you're that worried, or drill a 10mm hole and hammer in a dowel with a bit of PU glue, loads of ways.
  15. goldenboy
    Sometimes fixings can be overcomplicated.
    I pretty much use 3 types.
    Spit spirals for plasterboard
    Suitable screw and brown plug for bricks/blocks etc
    Multi montis for frames, casings and linings.
  16. DIYDave.
    We also don’t know what wall is built from so even with the best fixings, getting a good hold in lightweight blocks can be a pain
    Often you’ve only got 1 shot at getting a good fix from each hole as can’t move item over if wall crumbles :eek:
  17. Which is why I'm confused with Dryline Pro as it's just a long wallplug and long screw without the steel core.
  18. Jord86
    That's why I advocate PU glue, foam, ply etc.
