flat roof - how to repair felt coming away from brick upstand
Discussion in 'Builders' Talk' started by george100, Nov 12, 2017.
  1. george100
    george100 New Member
    Hi,
    I have a 15 year old flat roof. In a few places, the felt has pulled away from the brick upstand and water is getting in. I have had 2 quotes to repair it - without replacing the whole roof, which is the best method for a proper repair?
    method 1
    - cut away affected felt
    - sand and cement
    - prime
    - re-felt
    or method 2
    - grind back mortar bed
    - trowel on bitumen to build up repair and use grey acropol as a secondary seal
    Not much in the price, I'm more interested in what will fix the problem for the next 10 years?
    Thanks in advance!
  2. dobbie
    dobbie Well-Known Member
    Do you not have Arris rail fitted at the abbutment to the brickwork?
  3. BMC2000
    BMC2000 Active Member
    Saw cut a line above felt, insert lead counter flashing and method 1
  4. BMC2000
    Or lay Liquid Plastics all over roof and cut chase return liquid into chase and seal.
  5. KIAB
    KIAB Well-Known Member
    Definitely lead flashing as above.
    OP: Need a few photo's.
  6. dobbie
    Fit arris rail if there is not one there.
    Fit 6-9" of new felt to roof and lap up arris rail .
    Cut chase in wall, fit lead flashing and cement into chase.
    The arris rail and lead allows for movement, which when the felt is fixed straight onto the wall you do not have.
  7. george100
    here are the photos - what do you think?
  8. george100
    photos added - thanks
  9. george100
    Could someone comment on the photos please, now that I have added them. Is method 1 better? Do I need arris rail and/or lead flashing?
  10. dobbie
    Is that Asphalt in the photos?
    If it is, get an asphalt roofer who will repair it and give it a coat of solar reflective paint.
    When it was done it should have had an arris rail fitted with a lead flashing over that.
  11. KIAB
    Ignore it being a warm roof,& cavity wall, but it show shows aris rail & lead flashing (your missimg both) over the felt upstand, this standard contruction on a flat roof.
    Before soldier course laid, lead work should have been done, you can still cut a slot with grinder for it
    [​IMG]
  12. dobbie
    Kiab I asked if he had an Asphalt roof.If it is,it will more than likely be a cold roof.
    Why have you posted a drawing of a warm felted,not Asphalted roof to my question to the original poster.
  13. george100
    it is a felt roof
  14. dobbie
    Cannot see the picture too clearly and the first one looked like it could be Asphalt.
  15. KIAB
    I said IGNORE the warm roof,etc:rolleyes:, the diagram shows a similar construction of a flat roof, the location of arris rail the felt upstand & the lead flashing protecting the felt upstand, regardless whether a warm or cold roof, it's basically the same contrustion principle.
  16. george100
    2 builders have looked at it and both said it's felt - personally I could not tell the difference
  17. KIAB
    Replace with GRP wouldn't need to touch for 40 years or so.:D
  18. george100
    this photo shows it better - thanks
  19. dobbie
    Asphalt is about 3/4" thick when it is laid.
