Flat Roof (sloping) for Garage - advice welcomed
Discussion in 'Carpenters' Talk' started by DaveAlan, Oct 9, 2019.
  1. DaveAlan
    DaveAlan New Member
    Hi
    Wondered if I could get some advice to make sure I am on the right track before I make a mistake:
    1. 5.4m (225x75mm) joists being laid width of garage and each end strapped to block walls.
    2. To create fall perpendicular to joists architect states fillets to be screwed to each joist in ever declining height to create fall - so am gonna shave each fillet per joist to required fall.
    3. OSB3 T&G sheets applied atop fillets and screwed down.
    My main question is around the fillets - is this the best way since I can't use firrings as there is no support from front to back as joists run widthwise?
    Welcome advice, thanks in advance
    Best
    David
  2. candoabitofmoststuff
    Why can't you just use firrings at 90 degrees to the joists... Much easier, surely?
    Or am I missing something?
    Cando
  3. DaveAlan
    DaveAlan New Member
  4. The firrings do not need to go to nothing, they can run down to 1" or more and then run up to the size you need for the fall.
    If the sheets you are using are 8'x4' your joists will be at 16" centres and the boards will be able to have plenty of good fixings.
    Firrings are a better job than screwing decreasing sizes of timber to each joist and would be able to have the same amount of fixings.
  5. DaveAlan
    DaveAlan New Member
    Deleted member 11267
    I need firrings to fall 10cm over 5.6metres - admittedly these would be less fiddly than fillets but I assume I would require firrings every 600mm so I can affix the T&G board osb. Then the osb will not rest on anything along its short width with the only the T&G maintaining a connection. I suppose the firrings could rest on a lenthg of noggins to assist fixing?
  6. I would have the firrings at 16" centres or 400mm centres if boards are metric. Is the roof joists not at 16" or 400mm centres, if they are what is the difference when fixing the boards.
  7. Chippy mick
    Chippy mick Member
    Can always add noggins to fully support the firing pieces
  8. ginger tuffs
    ginger tuffs Screwfix Select
    could you use 95 x 45 then 70 x45 50x 50 38 x63 25 x 45 you can use these at 90d to joist
