Flexi hose where mains supply comes into house
Discussion in 'Plumbers' Talk' started by Catch22jones, Jul 9, 2021.
  1. Catch22jones
    Catch22jones New Member
    I've just had a new stop tap put in and because of the awkward position of the copper pipe, the plumber has removed a section of it and used a flexi hose instead. This is at the point where the mains supply comes into the house.
    I've seen some negative things about flexi hoses, so would appreciate your opinion on whether this is a good set up! The stop tap has also been installed after the flexi hose (which seems like an odd choice to me, because I would have to turn off the water from the street if there was ever a problem with the flexi).
    Is it worth me getting someone else in to put in copper pipe instead? Image of set up here: https://imgur.com/gallery/9FWDeuy
  2. Bob Rathbone
    Bob Rathbone Screwfix Select
    Looks rough to me, a very DIY type of result from a lazy plumber. I would not leave a job like that and I am not a plumber (electrician). Have you paid yet?
  3. teabreak
    teabreak Screwfix Select
    Megga bodge! He calls himself a plumber!
    OK as a DIY temp first aid job, but it needs doing in copper or at a pinch in proper plastic (lego plumbing to my mind) proper copper is the way to go in my view and try to get the stopcock controlling it too.;)
  4. just pumps
    just pumps Screwfix Select
    OMG!!!
    Worse use of a flexi I`ve seen.
  5. Mike83
    Mike83 Screwfix Select
    Don’t get much worse than that.
    Pathetic attempt.
    Temporary repair at best.
  6. Catch22jones
    I thought as much!
    He came initially to do the kitchen tap, but he sprayed water everywhere so offered to do the stop tap (which I'd asked for an additional quote for) for free. So luckily I only paid for the tap and not for this too.
    If I'd know what he was planning on doing, I would have left it. The stop tap was seized, but have bought a tool for the outside supply.
    Thank you for the advice all! Will definitely get someone else in. If anyone knows good plumbers in Leeds, would be happy for the recommendation!
  7. AnotherTopJob
    AnotherTopJob Screwfix Select
    Definitely replace the flexi. As well as being a weak point, it's probably restricting flow too.
    I can see why the angle of the incoming pipe makes it awkward, but to do it properly in copper should be an everyday job for a plumber.
  8. pppmacca43
    pppmacca43 Super Member
    I’m not a hater of flexis when used as tap connectors, but Jesus that’s really bad! Needs taking out and hard piping. Sort of thing u would do as a temporary repair certainly not permanent
  9. I-Man
    I-Man Screwfix Select
    bound to fail.... change it for coppper!
  10. FlyByNight
    FlyByNight Well-Known Member
    An Air Force** special.
    Did he ask you to feed his horse whilst doing it?
    ** R A F - Rough As F.....
  11. stevie22
    stevie22 Screwfix Select
    That is truly awful.
    A less worse bodge would have been to put the flexi after the stopcock and use a longer one so the bend was gentler.
    Muzungu likes this.
  12. Muzungu
    Muzungu Screwfix Select
    Exactly, at least when it bursts you would be able to shut it off!
  13. jonathanc
    jonathanc Screwfix Select
    Speed fit would have been way better too…
    pppmacca43 likes this.
  14. Mike83
    Chances are that was a straight bit pipe with the old valve on it.
    Probably guess that there’s no movement on the pipe that’s why he used a flexi.
    But we all know such small issues are easily overcome.
  15. Bob Rathbone
    To paraphrase Greg Wallace "Plumbing doesn't get rougher than this".
