Floor Insulation
Discussion in 'Builders' Talk' started by Dan1980, Oct 10, 2018.
  1. Dan1980
    Dan1980 Member
    Hi
    What is the best insulation to use in the floor of our loft conversion?
    Are there minimum standards for building regs?
    Our building control officer doesn't seem to care to much but I would like to do the right thing for sound/heat purposes.
    Cheers
    Dan
  2. Jord86
    Jord86 Well-Known Member
    200mm rockwool rolls will do just fine.
  3. Dan1980
    Dan1980 Member
    Thanks Jord
    Is there any need to use chicken wire to support it?
    Presumably rockwool is the stuff to use in stud walls also?
    Cheers
    Dan
  4. Jord86
    No chicken wire, just wedge it in before ceiling goes up. Can put it in a stud wall, but for sound reduction rockwool acoustic slabs are superior.
  5. Richard_
    Richard_ Active Member
    You can also use a resilient layer on the joists, ie a strip of foam or rubber.
  6. BMC2000
    BMC2000 Active Member
    Id say you'd need the chicken wire. The Rockwool you put in the floor for a loft conversion is for fire benefit. I had to put chicken wire in mine.
  7. BMC2000
    ...and acoustic benefit too as per Jord
