Floor joists required for garage conversion?
Discussion in 'Carpenters' Talk' started by ChrisCC90, Mar 14, 2021.
  1. ChrisCC90
    ChrisCC90 New Member
    Hi all,
    Quick Q regarding the flooring for a garage conversion.
    The garage has a concrete floor, im planning on insulating the floor, walls and roof, however im curious around the requirement for floor joists.
    i will be laying a DPM down ontop of the concrete, my Q is whether i should just put Celotex butted and taped together on top of this, or should i create floor joists and lay the celotex between them? I will be chipboarding and then laminating on top of this, but just curious on peoples opinions on the requirements of floor joists?
    my thoughts are because i will chipboard i will need the joists, but open to suggestions...?
  2. Severntrent
    Severntrent Screwfix Select
  3. CGN
    CGN Screwfix Select
    Bear in mind that a garage floor usually has a slope to it so you may need furring strips.
  4. Severntrent
    That's fur enough
    CGN likes this.
