Flooring grade chipboard
Discussion in 'Builders' Talk' started by Billyblade, Jan 11, 2008.
  1. Billyblade
    Billyblade New Member
    Does anyone know anything about the building regs. regarding flooring grade chipboard?
    With particular regard to
    a) impact strength required
    b) fire rating
    c) acoustic rating.
  2. _
    _ Member
    Billy,
    Building Regs will be dependant on the application (e.g. flats / house / domestic / commercial). I have used Sonae P5 flooring for refurbs and not had any issues see here:- http://www.sonaeuk.com/pdfs/sonaechipboard.pdf
    As I understand it you can show compliance using an appropriate CE marked material (which the Sonae board is).
  3. problem
    problem New Member
    most new houses going up use caberdek p5, but you have use it with the caberdek adhesive and tape.
