Flow and return temperatures
Discussion in 'Engineers' Talk' started by Baxi Boy, Nov 27, 2018.
  1. Baxi Boy
    Baxi Boy Member
    Can a heating engineer tell me if a flow temperature of 7degrees higher than return at combi boiler is about right in a small house? And the radiators also have a 6 or 7 degree difference,ie 60degrees flow side and 54degrees on return.
  2. KIAB
    KIAB Well-Known Member
    KUsuall differential is 11 degrees C (approx 20 degrees F).
  3. Baxi Boy
    Baxi Boy Member
    Yes,thanks for your reply I have read that 11 degrees is the usual,but with a small house with 6 small radiators,is it likely to be less,as I have 6 or 7 degrees?
