Can you use foam adhesive to stick foil backed insulated plasterboard to solid plastered walls? Has anyone tried? I have found 3 products, Insta Stik, Soudal foam adhesive, and Screwfix No Nonsense sticky foam. But one of the reviewers for one of these products claimed it did not work on foil backed insulation boards and just ripped away. https://www.screwfix.com/p/dow-insta-stik-expanding-foam-grab-adhesive-gun-grade-750ml/72793 https://www.screwfix.com/p/soudal-adhesive-foam-hand-held-750ml/9633h https://www.screwfix.com/p/no-nonsense-expanding-sticky-foam-gun-grade-750ml/6576h My preference is the Soudal one as its straight out the can and I won't have to spend around another £20 for a foam gun.
