Hi, X as you can see by the pics,i have used glands,albeit ive forgotton the rubber sleeves,***..do that later! Between the 2 glands of the isolator im gonna run a earth to the met in the hot tub,which is earthed through the cable back to main house met.Supply is on 32A mcb,protected by 30ma rcd,Surely this will be ok?
Dog rough job. No bonding, banjos not made off, supply most likely energised BEFORE testing. NON-COMPLIANCE AFTER NON-COMPLIANCE. Blinkin' eck. TT
you have forgotten to bolt the 2 banjos together and an earth lead from them. you have not sleeved the 3 core armoured in the control box.
Dog rough job. No bonding, banjos not made off, supply most likely energised BEFORE testing. NON-COMPLIANCE AFTER NON-COMPLIANCE. Blinkin' eck. TT 1. I ain t finished and 2.What i have done would be the time you get yer fooking thermos out the van!!
No bonding, banjos not made off, supply most likely energised BEFORE testing. No,i dont fooking think so cos i aint friggin FINISHED!!!!!
Hi, X as you can see by the pics,i have used glands,albeit ive forgotton the rubber sleeves,***..do that later! Between the 2 glands of the isolator im gonna run a earth to the met in the hot tub,which is earthed through the cable back to main house met.Supply is on 32A mcb,protected by 30ma rcd,Surely this will be ok? Didnt this give u a clue of my intentions!!
Between the 2 glands of the isolator im gonna run a earth to the met in the hot tub, why ? all you need to do is a nice earth between the gland banjos.
There aint room for gland up at the socket as it is set back into 2" of render,so i thought id earth it at the hotub where there is a known main earth.
There aint room for gland up at the socket as it is set back into 2" of render Surface = surface Flush = flush No prizes for fitting Fluface Banjos can be inside Photos shouldn't be taken until the jobs 100%
If I was inspecting the job.... I'd be very interested to look inside the isolator !! and also may I enquire the method of earthing
Not to dis your work buddy but i have to agree with the rest on these items dog rough it is and you should of taken photo´s when they were finished.
Yeah, and where's the ferkin gland for the flex? http://i183.photobucket.com/albums/x2/hugemcscrooge/Picture005.jpg Wouldn't trust you fit ******* to teddybears. TT [Edited by: admin5]
Come on chaps, give this guy a break. It's not like he's charged for his services. Just a little adjustment here and there and job's a goodun
Acca..mate..love the pics mate..it shows you are in reality..When everything is shipshape make sure you post a pic of the finished job (and head it finished job)..and show these grizzling so and so's a thing or two...
Well this was a home job that i was gonna take my time with over a few days but you barstewards wound me up so much i finished it off in the rain!! Least now i can sit in the consevatory and look at the beach!!!
Come on chaps, give this guy a break. It's not like he's charged for his services. Just a little adjustment here and there and job's a goodun Cheers Buster,needs finishing not adjustment tho..
