Freezer in shed
Discussion in 'Electricians' Talk' started by sparksmate, Feb 1, 2007.
  1. sparksmate
    sparksmate New Member
    A neighbour wants a freezer in his shed. I'm reluctant to put a socket on an RCD incase of nuisance tripping & if I put a none RCD socket in there it could be used for other purposes.
    Any reason for not wiring it to a fused spur??
  2. JP.
    JP. Screwfix Select
    Extraneous....ie..Outside In Shed = Away from the central core
  3. ban-all-sheds
    ban-all-sheds New Member
    Any reason for thinking that it's reasonable to unplug a freezer to use the socket for something else?
  4. sparksmate
    central core
    I feel there may have been drugs involved in this answer.
  5. starlight tiles
    starlight tiles New Member
    freezer in a shed.are the gypsies.
  6. Mr. Handyandy
    Mr. Handyandy Screwfix Select
    spur??[/QUOTE]Any reason for thinking that it's
    something else?
    Yes. If it is the most convenient socket, it is, or would be QUITE reasonable to unplug the freezer for say, an hour, to plug in a mower to cut the grass.
    A good freezer(well sealed type of good) will keep food frozen for 24 hours(unopened) with no power.
    Mr. HandyAndy - really
  7. fooman
    fooman New Member
    20amp 2.5 radial to it with a normal socket for the freezer and another next to it with build in rcd.
    Job Done :)
  8. hertssparky
    hertssparky New Member
    Shed outside the equipotential zone.
    RCD protection required.
  9. allycat
    allycat New Member
    you only need an RCD if it supplid from a socket that can be used for hand held equipment. If you use a fused spur there is no requirement for an RCD
  10. sinewave
    sinewave Screwfix Select
    Utter Bollox that allycat, sorry! :(
    Any socket that is outside is 'likely to be used for handheld equipment' and thus should be RCD protected.
    Whether it's supplied from a FCU is irrelevant! ;)
  11. unphased
    unphased Screwfix Select
    I'm
    Quite right. Stick the freezer on a fused spur. If you want to add a socket use an SRCD plate.
    UP
  12. unphased
    As foo said but mine is more crectly described (SRCD). ;)
  13. I hope he adequately protects it from Frost damage!
  14. ban-all-sheds
  15. NorthernSparks
    NorthernSparks New Member
    Cut the plug off the freezer & wire it directly to a switched FCU . Outlet can't be used to supply portable equipment outside so no RCD required.
    N S
  16. ban-all-sheds
    Or use a plug/socket with a non-standard earth pin.
    Or provide an unused RCD socket nearby and as the design authority determine that it would be unreasonable to unplug the freezer to use its socket for something else.
  17. MOONSHINE
    MOONSHINE New Member
    fooman
    Re: Freezer in shed
    Posted: Feb 1, 2007 8:39 PM Reply
    Job Done
    This is the only way. Why would the guy want to unplug the freezer? When he can fit a double adapter.
  18. Jake45
    Jake45 New Member
    for something else.
    The problem arises when, in the future, someone decides not to have the freezer in the shed and you are left with two sockets that can reasonably be expected to be used outdoors (one for the pond pump, one for the strimmer).
    You should decide the status of a socket outlet by it's location, not by what is currently plugged into it.
    Jake
  19. ban-all-sheds
    I disagree.
    If someone in the future makes changes to the environment for which you have designed, and in doing so creates a non-compliance, that cannot be your responsibility.
    You cannot second-guess, or guard against, what might happen in the future. If your design is compliant at the time then that is sufficient.
  20. Jake45
    Jake45 New Member
    I disagree.
    responsibility.
    How can you design an environment that is dependant on what people (without electrical knowledge) may or may not plug into socket outlets???
    Your design is not compliant if it fails to protect people who innocently unplug an item.
    I think you may be 'batting a sticky wicket' with this one BAS:);)
    Jake
