Fridge and freezer wiring
AlbertTatlock
New Member
We have a small café and are in the process of purchasing a double stand up fridge and a single stand up freezer both are 1900mm high and my question is will they run off the 2 existing 13amp fused spurs that we already have or will we need heavier supply cables to the consumer unit. Thanks in advance Albert
You will be fine. When you first plug them in, switch them on separately to allow the motor in the first to start and get running, it needs only 2 or 3 seconds, then switch on the second unit. Fridges and freezers draw a large start up current, but once running the current drops significantly. During normal opertion, the thermostats in each unit will switch on at different times avoiding a double start up current rush.
Back
Top
