Gap between the tiles and the skirting board
Discussion in 'Tilers' Talk' started by Iron_Mike, Dec 8, 2017.
  1. DIYDave.
    DIYDave. Screwfix Select
    As an aside, what colour grout are you going for ??
    Just if it’s white grout, on a floor, it won’t stay that white after 6 months, more greyish unfortunately
    If your going for white, look into epoxy grouts. More expensive / more difficult to use and finish / more time to apply / more hassle all over / but far superior properties against staining and discolouring against cement based grouts
    Dunno if you would trust your tiler though with epoxy after this unfortunate mistake
    Anyway, worth a look, but you may be going for a colour anyway so not such a problem
  2. Iron_Mike
    Iron_Mike Active Member
    Going with Gunmetal,which is a light grey.
    I have highlighted the issue with our tiler and the fact scotia beading is going to be needed to hide the fault.
    This has gone down like a lead balloon.
    He does not believe any real issue exists and that chiselling into the plaster and using slither tile cuts isn't a problem.
    Was not what I expecting to hear.
  3. Springbok43
    Springbok43 Member
    Have you hired a clown?
  4. CGN
    CGN Screwfix Select
    How have the tikes fallen on the opposite wall with regards to the skirting?
  5. Iron_Mike
    On the other wall, the tiles are too wide, so tiler has chiselled into the plaster to fit them in.
    The impression I got from speaking to him, was that I was making a mountain out of a molehill. But ultimately, I will have to spend extra money on scotia beading and glue due to a tiling error.
    Let alone the time wasted chiselling into walls.
  6. DIYDave.
    :rolleyes: Don’t understand the bit about chiselling into the plaster on both sides to make the tiles fit ?
    Surely you just cut them to size
    I’m only diy but have done a fair bit of tiling in several properties over the years
    I always think and plan the layout for ages and in particular, where cuts will fall, where whole tiles will sit and avoiding slithers at ends/corners
    But, there seems to be so many different opinions on laying out tiles. Some measure wall/floor dead centre and tile outwards from this line - still checking before you start what size tile you will end up with either end
    Some start a wall with whole tile and end with cut, starting joining wall with another cut tile and so on
    I like symmetry myself, takes more working out, not always possible working around say a bath and windows but firstly planning the lay out is massively important, even dry laying a row or two, including the spacers you may be using
    Politely tell the tiler how you would like your floor to look, and how you have decided to deal with the gap. Slithers never look good, and these will be approx 20mm ? Rubbish
    If he’s not happy, tell him to pack up and leave the job, no point carrying on with a bad attitude
    Work out what you may owe him for work completed, materials, then minus an amount for poor planning, delay, contracting another tiler to finish and any other materials now needed - ie trims
    Good luck
  7. Iron_Mike
    His wet cutter has broken and he is suggesting cutting tiles with an ankle grinder instead...
    I not happy with this, as how can an ankle grinder get you sharp cuts?
  8. CGN
    CGN Screwfix Select
    What type of tiles are they mike?
  9. Iron_Mike
    Porcelain
  10. CGN
    CGN Screwfix Select
    How thick? Should be able to dry cut.
  11. Jord86
    Jord86 Screwfix Select
    Putting all other issues to the side, you can get a clean cut with an angle grinder with a decent diamond blade.
  12. Mr. Handyandy
    Mr. Handyandy Screwfix Select
    I'd also like to know about this 'chiselling into plaster' effort.
    What?
    Mr. HandyAndy - Really
  13. CGN
    CGN Screwfix Select
    Prob starting against the far wall with a full tile, but wall not quite straight at some point so chiseling a bit out to save cutting the tile.
  14. Iron_Mike
    20mm
  15. Iron_Mike
    Think to free up a few more mm so the slither tiles are not as anorexic.
    Considering the full size tiles are 600 x 600, having 30 mm tiles as you come in will look weird.
  16. Iron_Mike
    Hi, just getting to the back end of this job now.
    In regards to the area I am covering with slither tile cuts, as these will be covered by skirting and scotia beading, could I bring the level up with self leveller and avoid having to wet cut a bunch of angled 20/30mm tiles?
  17. Wayners
    Wayners Screwfix Select
    9mm board over the wall and skim.. Pack wall out basically.. Can't see any other way other than bodge up
  18. CGN
    CGN Screwfix Select
    Yes
    Iron_Mike likes this.
  19. Iron_Mike
    I have a light and rad fitting, so can't do this.
    But with the scotia beading, I can cover it up.
  20. koolpc
    koolpc Screwfix Select
    Agree
