Gap from floor to wall
Discussion in 'Builders' Talk' started by Thesecondfavourite, Jul 24, 2021.
  1. Hi, i have been taking up flooring in a room in my house. I noticed that near the door a patch of damp concrete. So I gave it a scrape and it just broke away, almost like sand! So I've removed the lot and now need a solution to refill the gap. Should I just use a sand cement mix? Thanks Screenshot_20210724-175939_Gallery.jpg Screenshot_20210724-175929_Gallery.jpg
  2. Abrickie
    Abrickie Screwfix Select
    You may want to extend the DPM before you do, otherwise the same thing will happen again :(
    Thesecondfavourite likes this.
  3. Perfect, so there is light at the end of the tunnel!!
    Thank you
