Garage Conversion
Discussion in 'Builders' Talk' started by pde100, Nov 16, 2018.
  1. pde100
    pde100 Member
    IMG_0291.jpg hello
    I recently our house attached garage insulated and ceiling put in. I was examining the gutters and noticed the attached. Seems the soffit has come away from the wall (think that's the correct term). Feels like the roof beams are pushing against it so not sure how long its been that way. The new celling isn't wet in that corner so not an urgent problem but clearly not good!
    Any advance would be greatly appreciated.
  2. blarblarblarblar
    blarblarblarblar Active Member
    Are you saying that this has just happened, this looks like it’s been like it for ages?
  3. Isitreally
    Isitreally Well-Known Member
    Fascia board, soffit goes underneath.
    Though your could be called a bargeboard as its directly on the wall.
  4. Isitreally
    Anyhow back to your pics, because your boards are fitted directly on to the roof joists it would suggest some movement in the joists, them getting wet would cause this.
  5. pde100
    pde100 Member
    Yes I’m not sure how long it’s been like that. It may be I haven’t noticed. I’m not sure if I should just use sealant to attach it back ? Or is there a better way ?
    Thanks
  6. pde100
    pde100 Member
    thank for any advice with this
  7. pde100
    pde100 Member
    hello any advice on how to attach the bargeboard would be appreciated, thanks very much in advance, greatly appreciated
  8. pde100
    pde100 Member
    Does anyone know I good way of fixing the boards back if the wood has moved?
    thanks for any advice
  9. pde100
    pde100 Member
    hello I'm going to use sealant, does this sound ok?
