Garden office
Discussion in 'Painters' Talk' started by Stuart74, Jun 14, 2019.
  1. Stuart74
    Stuart74 New Member
    Hello
    I have recently bought and had installed a Garden Office. (www.warwickbuildings.co.uk)
    I was hoping for some advice on what type of paint I can use for the INTERIOR. Can I use normal emulsions, (e.g. dulux)? I was hoping to do the ceiling white and the walls an off white
    shade.
    Thanks
    Stuart
  2. Hans_25
    Hans_25 Screwfix Select
    What timber is on the interior and is it treated at all?
  3. Stuart74
    Stuart74 New Member
    Hello
    It is tongue and groove timber, I think untreated, but I am asking the company to confirm exact details.
  4. masterdiy
    masterdiy Screwfix Select
    Knowing as we do about T&G, has it a waterproof membrane under the T&G.
    Otherwise, movement, cold & heat will allow boards to move??
    "I was hoping for some advice on what type of paint I can use for the INTERIOR. Can I use normal emulsions, (e.g. dulux)? I was hoping to do the ceiling white and the walls an off white
    shade".
    Dont see a problem with that.
  5. Stuart74
    Stuart74 New Member
    Hi
    The wall construction has a membrane underneath the T&G. before it gets it the outside layer of the garden office.
    Thanks
    masterdiy likes this.
  6. Hans_25
    Take a look at the Sikkens range, the Rubbol Satura Plus is a good one for this application I think, is available in white, not sure about other colours. I find the Sikkens range to be good quality but very confusing.
  7. Astramax
    Astramax Screwfix Select
    As its an outside timber office consider Bedec MSP (multi surface paint) as it will cope very well with fluctuations in temperature therefore resisting cracking along the t&g joins.
    KIAB likes this.
  8. masterdiy
    Astra, INTERIOR.
  9. Astramax
    YES...I know, what's the problem! Highly flexable, no priming required, suitable for both interior and exterior use.;)
    masterdiy and KIAB like this.
  10. Stuart74
    Stuart74 New Member
    Thank you for your replies
  11. Stuart74
    Stuart74 New Member
    Please may I ask. As the OUTSIDE is clad in Cedar I was considering using RESTOL. Is this a good choice?
  12. Astramax
    Never have used it, however RESTOL has favourable reviews which is a bonus and contains linseed oil so can see no reason why not, follow the instructions though.
  13. Ben Michelle
    Ben Michelle New Member
    Resene staff and provided to enable you to gain a greater understanding of the substrates and paint systems you may encounter in your decorating project. It almost cover all decorating scenarios in a single document, https://docsbay.net/resene-popular-paint-systems hope that helps
