Gas boiler burnt through boiler wall!?
Discussion in 'Getting Started FAQ' started by Casey123, Nov 4, 2018.
Tags:
  1. Casey123
    Casey123 New Member
    Hello, got home after a long day, ready to have a shower and notice a giant mark on the gas boiler in the bathroom...it looks like the fire in the boiler has somehow managed to burn through the wall! I’ve told all family members to stop showering or use the hot water tape. How do we fix this? I guess it would definitely need a replacement. Who would be most suited for the job? A plumber or someone else..? Slightly worried..please see attached image.
  2. CGN
    CGN Well-Known Member
    Yep, a heating 'engineer'.
  3. KIAB
    KIAB Well-Known Member
    :eek:
    Never seen that before.:eek:
  4. candoabitofmoststuff
    candoabitofmoststuff Active Member
    Blimey!
    I'd be really interested to hear what the cause turns out to be.
    Has the boiler been regularly serviced?
    Cando
  5. KIAB
    Me to, hope OP has smoke alarms fitted.
  6. Pollowick
    Pollowick Well-Known Member
    I would also suggest contacting the manufacturers of the boiler - for a case like that, they would want to know.
    And if you have it repaired - retain all damaged parts.
    Casey123 likes this.
  7. Casey123
    Casey123 New Member
    Thanks for all the replies, there is no smoke alarm fitted in the bathroom D: (It's my parents' house) I've already told everyone to not use the hot water or shower..but someone decides to have a shower in the middle of the night anyway...(there are a couple lodgers in the house).
    I am an engineer myself, and showed colleagues the photos this morning..they suggested getting a gas certified plumber to look at it.
  8. Casey123
    Casey123 New Member
    No the boiler has not been regular serviced, when the hot water tapes are turned on, the circuit sparks the flame within the boiler to instantly heat the water. There is no storage of hot water.
  9. Muzungu
    Muzungu Active Member
    Had a problem with my Vaillant 240 vcw (open flue) where a bit of insulation had come away inside the burner box and fell on top of the burners, flames shooting out every side, possibility? Anyway Gas Safe plumber is called for.
  10. KIAB
    Repaired!:eek:
    Fit new, peace of mind, & a warrenty.
    All for contacting manufacturers, might be able to screw a new boiler out of them.:)
    Chaffoteaux Britony.
    http://www.aristonthermo.com/en/Brand/chaffoteaux
  11. Allsorts
    Allsorts Well-Known Member
    :eek: I suspect that boiler hasn't been serviced for quite a while...
  12. candoabitofmoststuff
    As it hasn't been serviced regularly I wonder if it's a build up of combustion debris that has collected into a "lump" and is acting a a heat reservoir, resting on the cover. It's obviously something localised.
    Cando
  13. Casey123
    Casey123 New Member
    Thanks! Just emailed them, hopefully get a reply soon.
  14. candoabitofmoststuff
    If you don't use gas for cooking, and it's only used to feed the boiler I'd consider turning the gas off at the meter. That way when lodgers complain of no hot water you can "blame" the boiler itself.
    Cando
  15. Casey123
    Casey123 New Member
    That sounds very likely. I haven't lived there in a while, only moved back into this house about a year ago so I guessed that the likelihood my parents had it regularly serviced is very slim.
  16. The Teach
    The Teach Well-Known Member
    seen them before with a scorched case,there are a few reasons why.
    that water heater needs immediate action to make it safe,If used there is a possibility carbon monoxide will enter the room due to the melted & distorted case seals and other reasons also what looks like a cardboard box on top of the heater could ignite :(
    if the pilot is lit the controls on the heater are still set to allow it to fire up when a hot water tap/shower is turned on,best call in a gas safe technician to make safe the appliance and quote for repairs/new appliance.
    Thats an old appliance probably been there for 25+ years :(
    Casey123 and KIAB like this.
  17. KIAB
    If the heat has done that to cover, is there the chance it has also distorted the burner/combustion cover,allowing carbon monoxide to escape?
  18. Casey123
    Casey123 New Member
    I didn't even think of carbon monoxide as an issue...my immediate thought was risk of explosion and second thought was if it does burn through eventually, there is a chance that the boiler can have a higher pressure build up inside than the surrounding atmosphere, this would lead to the fire misfiring outwards into the atmosphere rather than drawing air in. (I worked with furnaces and fired heaters a few years ago in an oil refinery...)
    I am not taking any risk but the lodgers seems to be ignorant to the hazards...I've turned the two dials on the boiler off and water temp to the minus sign. Also switched off the electrical going towards the shower on the main switch board...not sure if it helps.
    P.S. Ariston (aka Chaffoteaux) the manufacturer got back to be and classified it as 'immediately dangerous' and advise 'not to turn on the unit and call for a competent gas engineer to inspect'. No mentioning of offers of their engineers to inspect or replacement though.
  19. DIYDave.
    DIYDave. Well-Known Member
    Wow...... no S hit Sherlock
    Would think so as well, makes more sense than your window cleaner or local fish monger :)
  20. KIAB
    Turn gas off at meter, remove handle,need to remove split pin,but will stop lodgers turning on gas.
