Gas connections
Discussion in 'Plumbers' Talk' started by bigjules, Jan 19, 2008.
  1. bigjules
    bigjules New Member
    Why is it that a free standing gas cooker can be connected with a flexible hose (and chain) but a fixed hob must have rigid piping?
  2. doitall
    doitall New Member
    Where did you read that :O read the manufacturers instructions, hoses are permitted in most cases for hobs.
  3. tomplum
    tomplum Active Member
    i don't think we're all singin from the same hyme book here,
    rigid pipe is always preferable, flexi for cleaning purposes,
    hoses are permitted where clearance for temp is achievable under a hob,
  4. twoinchnipple
    twoinchnipple New Member
    are you sure about that doitall,i thought fixed appliances should be piped rigid like the op says
  5. doitall
    doitall New Member
    Positive
  6. user28
    user28 New Member
    Because cookers are free-standing and hobs are fixed.
  7. doitall
    doitall New Member
    Good post user 28, :(
  8. screwhard
    screwhard New Member
    hobs.
    I,m afraid theyre not allowed under hobs,because of the heat transference from beneath the hob could melt the hose.trust me ive done thousands
  9. Walterfilter
    Walterfilter New Member
    for
    hobs.
    read this example of manu facturers instructions...page 7
    http://www.micromark.co.uk/awt/25626-060904.pdf
    personally I've always gone for a rigid install....
  10. screwhard
    manufacturers
    for
    hobs.
    of
    melt
    Well what can you say,on my last assessment i was asked what is wrong with this installation, it was a hob fitted with a flexible hose,i told him,yes,he said flexis are not allowed ,they have to be rigid fixed??
  11. oliver1234
    oliver1234 New Member
    I have always been under the impression that there is no fixed regulation on this issue and it depends on what the recommendations in the MI say. Doesn't it depend on whether or not there is an oven below the hob as well in some cases?
  12. Walterfilter
    fixed??
    Often on that type of 'set-up' assessment, the MI is left nearby for you to check on install instructiions to assess a faulty install.....maybe that particular hob was rigid instal only? some are....
  13. screwhard
    a
    fixed??
    hob was rigid instal only? some are....Having said all that, I will still continue with rigid fixing on hobs
  14. mrj
    mrj New Member
    The rules are very simple, if the MI's say you can fit it with a flex then you can, PROVIDED you meet the criteria of the MI's. If they say you can't, then you can't. simple really.
  15. doitall
    doitall New Member
    hobs.
    Keep going guys ;) ask if you don't know :)
  16. screwhard
    for
    hobs.
    smart ****.
  17. doitall
    doitall New Member
    B-):p
    Don't you just hate a smartarse :O
  18. screwhard
    B-):p
    every dog has his day]:}
  19. screwhard
    B-):p
    hey doitall, I can do sunglasses B-)cool
  20. doitall
    doitall New Member
    :mrgreen: :roll:
