Any heating engineers / gas fitters out there? I have an open gas fire, model specific replacement coals ( preformed shaped blocks ) are going for £100-£200, whilst individual 'coals' are being offered for approx £1 each. Is there any reason I Shouldn't attempt to make up the display using the individual coals? It's my intention to arrange a gas maintenance check so saftey is taken care of Many thanks in anticipation
The arrangement of the coals is purely for decorative effect. Putting them in the wrong place will not allow the flame to heat them to red heat where required for best appearance. Why not put the £100 towards a new gas fire with an enclosed front (glass panel) which will be more efficient as less non combustion air is drawn up the flue.
Hi thanks for reply, it has a glass screen and other than the screen wanting a clean and the coals replaced the fire is good for a few years yet. For the sake of £20/£30 quidish may have a go and try and replicate the layout, do you think?
Yes, as the gas fire has a screen and is probably a higher efficiency model, go for it. I am not gas safe registered, if you are unsure then consult a gas safe type.
This really depends on the make and model of gas fire. Some coals need to be in a specific location due to the burner.
