Gas geyser for running a shower
Discussion in 'Plumbers' Talk' started by azizrasul, Aug 12, 2018.
  1. azizrasul
    azizrasul Member
    Hi,
    Can anyone recommend a gas geyser for the sole purpose of running a shower. I assume a water mains pipe is connected to it as well as a gas connection.
  2. just pumps
    just pumps Active Member
    Can you explain "geyser" in the context of your question?
  3. The Teach
    The Teach Well-Known Member
  4. rogerk101
    rogerk101 Well-Known Member
    I have to assume the original poster is South African, because water heaters/cylinders are referred to as geysers over there.
    The gas fired 'Junkers' geysers that are very common in South Africa, and which heat shower water on demand usually from bottled gas, are not really found in the UK. I personally haven't seen them for sale here.
  5. MGW
    MGW Well-Known Member
    I have a Main 7 in my house, it works fine with shower, however it is rather old, not sure you can get them any more? They had no electric connection. But when combi came out think they stopped making them.
  6. azizrasul
    azizrasul Member
    I meant a gas fired unit to get hot water for a shower.
    I don't want an electric shower as I already have one in the house and I don't want it to trip if both are being used simultaneously.
  7. NoOhmToGoTo
    NoOhmToGoTo Active Member
    You don't want what to trip?
  8. azizrasul
    azizrasul Member
    If I have two electric showers being used simultaneously, I don't want one of the showers to trip at the consumer box as the combined current may be too high. I have a 100A fuse. I live in the UK.
  9. Vin
    Vin Active Member
    Vokera make a gas boiler for water only.
    Google Vokera Easi flo
  10. azizrasul
    azizrasul Member
    Many thanks Vin.
  11. rogerk101
    100A at 240V = 24kW.
    That would allow two showers to run simultaneously provided they less than 12kW each, and provided no other power hungry devices are running (e.g. kettle, stove, etc.)
    With all the hassles involved with gas, I'd stick to electric if it were my house.
