Hello, What is the closest distance a fitted gas hob can be from a wall or an adjacent unit which is taller than that of the unit the hob is fitted to? regards
It will all be in the instuctions or if there are no instructions consult the relevant British Standard. Mike
as everyone else says as per manufactures instructions from combustible materials:- a hob in a worktop normally has 50mm on all sides rising to 760mm above the hob. where as a free standing cooker with a grill has 20 mm around the oven, 150 from the hotplate (top of the worktop)rising to 610 mm above the top of grill metal edging strips should be fitted to worktop edges by hotplate Jacen
